The Solution Deployment Tool will not upgrade or modify any already deployed items, this is because once deployed the items can be modified and would be very difficult for us to push the enhancements in place. However, when you deploy an update we will only create new versions of the enhanced items. For example if we enhanced a web application in the solution we will only deploy the new web application, on top of the existing web map and feature layers in your organization. So you won't need to re-load your data. If we need to modify the layers to change the schema we will deploy the new layers and maps and apps on top of the layers.
