Transferring the layer of points that has UTM 6 degree ED50 datum from ArcMap to Google Earth
5004
08-17-2015 05:43 AM
özgürökçün
If I want to transfer the layer of points that has UTM 6 degree ED50 datum from ArcMap to Google Earth, is a necessity to convert points from ED50 to WGS84? Google Earth is based on WGS84. I am thinking ArcMap maybe convert to WGS84 automatically, because KML is working with just WGS84. Or maybe I need to Project tool for convert? Which one is true?
NeilAyres
MVP Alum
You will need to project - UTM metres to GCS (geographic degrees) and transform the datum from ED50 to WGS84.
Datum transformations :
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
You can do this in 1 step in the project tool or export from the data frame in ArcMap.
özgürökçün
thank you
NICOLAPEDDIS
Occasional Contributor II
You can search here
ArcGIS Help 10.1
and use the toolboox.
Also a good program to change coordinate system is Global Mapper
özgürökçün
thank you
