Adding text to a number in label expression
8639
06-30-2015 08:19 AM
AlmazNaizghi
New Contributor III
I was able to add a text below the number in Label Expression when I was using ArcGIS 10.2.1. However, recently I upgraded my ArcGIS to 10.3.1 and I was not able to do it. Please see below, the screen shot of what I did with the error message. I look forward for any help to what the case could be? Thank!
TomSellsted
MVP Regular Contributor
Almaz,
For your expression you could use:
[Area_Acres] & vbcrlf & "Acres"
Using the vbscript option.
Regards,
Tom
TomSellsted
Almaz,
Regards,
Tom
IanMurray
Hi Almaz,
If Area_Acres is a numeric type field, you will need to change it to:
str([Area_Acres]) + '/n' + 'Acres'
Otherwise its seems there is a problem with your install of the numpy module.  ArcMap 10.3 is supposed to use the 1.7.1 version and is supposed to be installed on your computer with 10.3 if it is not detected, though if you did a custom install, you could have skipped it.
ArcGIS 10.3.x for Desktop system requirements—Help | ArcGIS for Desktop
If this is indeed the issue, you might look at downloading and installing the module seperately instead of reinstalling ArcGIS 10.3
numpy 1.7.1 : Python Package Index
AlmazNaizghi
New Contributor III
Hi Ian,
I tried with:  str([Area_Acres]) + '/n' + 'Acres'
It didn't work and gave me error message.
I will double check if the 1.7.1 version has been installed to my computer with 10.3.
