I am trying to set up a layout templates for the export web map tool. The layouts I am using have a black background. I understand that you can change the text color of the legend in a map document by clicking properties -> items on the legend but however, if I remove all the layers and then re-add them, the color will go back to the deafult "black" which then can't be visible on my black backround.
Is there a way to set up the templates to recognize a specific color as the legend text default so when I use the export web map tool, the exported map will not have a legend with black text?
