It is not obvious, but the extra zeroes can be eliminated by changing a setting that is buried in the Graticule properties. I don't remember exactly which setting it was (and don't have the software in front of me at the moment), but there is a setting that can be changed.
I'd suggest going into Data Frame Properties, click on the Grids tab, highlighting the Graticule you want to modify, then clicking on the Properties button. Then walk through the tabs, which looks exactly like when one is stepping through the wizards. The setting that changed it was not on the tab one would assume it should be on. It was called something like "font" or "style" and it was small and easy to miss. It will take a bit of poking around, but it is there.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Chris Donohue, GISP
