Consistent Colors/Symbology in ArcMap
2552
12-01-2016 01:59 PM
AnnH
Hi Guys,
I am wanting to keep the colors consistent for multiple layers. I have a point layer, a line layer, and polygon layer. There are unique individuals, of which have a point, line, and a polygon. Therefore, I want the color of the point, line, and polygon to be same for the unique individual. Is there an easy or straight forward way to do this, as I have 100s of individuals and do not want to manually assign the same color three times.
Thank you all for your help!!
DanPatterson_Retired
if the classifications are the same, then choose your color scheme and save your prefered symbology to a layer (*.lyr) which you can load and reuse with similar data values and ranges.  Barring that, get your rgb values and use those.
AnnH
I apologize for my limited knowledge, but how do you save symbology in a way that can be loaded to other layers? Thank you for your help!
Sent from my iPhone
some links
Save To Layer File—Help | ArcGIS for Desktop
Importing symbology from another layer—Help | ArcGIS for Desktop
And your general symbology stuff in the help topic on the appropriate symbols to use for a given data type etc.
A quick tour of displaying layers—Help | ArcGIS for Desktop
good luck
