Dynamic symbology for Data Driven Maps
5616
03-31-2011 07:59 PM
JustinOdell
I am creating a series of map products based on a boundary line feature class.
I am able to change the area of interest for each map based on different lines within this feature class.
However what I am hoping to achieve is creating some dynamic symbology so that every time I click through the data driven maps, the boundary line in question is highlighted as red.
How is this possible?
maxsteinbrenner
one trick you can use to avoid custom symbology is to just change your selection color to the desired "custom" color and then just the selected polygon boundary to highlight your particular area of interest.
JustinOdell
Thanks for the suggestion, however the line does not become selectable when flicking through each data driven page.
Edit: Problem solved by following the tip below:
There are actually now two ways to highlight the page you are on. One is with the Page Definition Queries, the other is with some new options in Clip to Shape.
The Page Definition lets you filter features that have attributes that either match, or don�??t match the name of your data driven page index feature. The option to set a Page Definition is a button on the Definition Query Property page, but the button only shows up if 1) you have Data Driven Pages enabled and 2) if the layer is NOT the Index Feature layer.
Using Page Definition Queries, if you want to highlight the page you are on:
1) Copy the index layer to another layer in your TOC and place it above the Index layer in the drawing order.
2) Set the symbol property of the new layer to the color you want to use to highlight the page.
3) In the Definition Query property page of that new layer, select the Page Definition button.
4) Enble the Page Definition Query to "Match" the same attiribute used for your Data Driven Pages.
The help topic for the Page Definition Queries is at:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00sr00000004000000.htm
Clip to shape gives you another way to do this.  If you have Data Driven Pages enabled and you go to the Data Frame Properties, under Clip Options there is a new option to "Clip to current data driven page extent." Then there is a button to "Exclude Layers".  This lets you pick the layers that you don't want Clipped.  You can achive all sorts of interesting results by chosing different layers you want to show in the Index feature area, and features you want to show outside of the Index feature. You might want to play around with this a bit to see what you can acomplish.
The help topic for the new Clip to Shape options is at:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Clipping_the_Data_Frame/00s90000000q00...
SamanthaAvant
I had the same questions and this worked great! Thanks!
