findAndReplaceWorkspacePaths crashes when mxd contains image layers
3883
17
02-12-2011 03:47 AM
DonMcClimans
I am moving a large number of mxd files, and need to update the data sources for various layer files. I have written a script that uses findAndReplaceWorkspacePaths. The script works fine as long as the mxd does not contain an image service layer. If it does contain such a layer, the script crashes. I am not trying to change the path in the image layer, but other layers in that mxd file.
This looks like bug NIM060315 http://resources.arcgis.com/content/nimbus-bug?bugID=TklNMDYwMzE1, except I am not trying to change the image layer itself.
The bug report lists no workarounds. Is there anything I can do? Doing these by hand will be a big undertaking (and error prone).
Thanks
deleted-user-9ppwtkjpkhrH
New Contributor II
I'm at SP 2.  The following Python script was a successfull work around.  Note, I'm not experienced in arcpy so judge accordingly (although, hey, it does work!):
import os, sys, arcpy
import arcpy.mapping as MAP
mxdPath = sys.argv[1]
oldDataSource = r'P:\cby\gisprojects\umpqua\Phase_II'
newDataSource = r'P:\cby\gisprojects\umpqua\Soup_Cr_VRH'
arcpy.overwriteoutput = 1
mxd = MAP.MapDocument(mxdPath)
for lyr in MAP.ListLayers(mxd):
    if lyr.supports("DATASOURCE"):  # note, this caught some of the image service layers but let one slip through
        if lyr.supports("SERVICEPROPERTIES"):
            if lyr.serviceProperties['ServiceType'] == "ImageServer":  # note, this caught the image service layer that slipped through the first "if" statement
                pass
            else:
                lyr.findAndReplaceWorkspacePath(oldDataSource, newDataSource, False)
        else:
mxd.save()
del mxdPath
del oldDataSource
del newDataSource
del mxd
JeffBarrette
This should have been addressed at 10.0 SP3 with NIM067149: Block Web service layers from supporting layer.dataSource.  The example in the previous post solves one problem but will introduce another if something.
The correct solution should be:
I just confirmed this on a 10.0 SP3 machine. Image Server layers no longer show up as layers that support the lyr.support("DATASOURCE") property.
Before attempting to change a data source, check to see if this property is true.
for lyr in arcpy.mapping.ListLayers(mxd):
    if lyr.supports("DATASOURCE"): If you are still having a problem, please send me a map package so I can test with your data.
Jeff
StephenIrving
New Contributor II
Hello Jeff,
I, too, am having a great deal of trouble with this issue.  I am running ArcGIS 10 SP4 and attempting the following:
import arcpy, os
folderPath = r"G:\US_Army_COE_Sac\ERS\Ft_Irwin\_MXDs\Checker"
for filename in os.listdir(folderPath):
    fullpath = os.path.join(folderPath, filename)
    if os.path.isfile(fullpath):
        basename, extension = os.path.splitext(fullpath)
        if extension.lower() == ".mxd":
            print fullpath + "\n...Checking"
            mxd = arcpy.mapping.MapDocument(fullpath)
                    mxd.findAndReplaceWorkspacePaths(r"G:\US_Army_COE_Sac", r"G:\US_Army_COE_Sac\ERS\Ft_Irwin")
            print fullpath + "...Updated"
            mxd.save()
del mxd
I have also tried looping through each layer after the "DATASOURCE" test using layer.findAndReplaceWorkspacePath() with the same result of a full crash. The MXDs each have a Bing streaming imagery layer in the TOC and the script works fine if i remove it.
Thanks in advance for any ideas on why this is still not working....
Steve
JeffBarrette
I was able to reproduce using Bing Maps Aerial basemap.  The higher level "Basemap" group layer does NOT support "DATASOURCE" but the sub-layer "BingMapsAerial" unfortunately does (the value is an empty string).  We'll need to correct this.
In the meantime can you try:
    if lyr.supports("DATASOURCE") and lyr.supports("DATASETNAME"):
The BingMapsAerial sub-layer does NOT support "DATASETNAME".
StephenIrving
New Contributor II
Sweet!
Thank you that works well!
Steve
StephenIrving
New Contributor II
Sweet!
Steve
Looks like i spoke a bit too soon.  Now it is throwing this error:
Executing: MXDSourceUpdate G:\US_Army_COE_Sac\ERS\Ft_Irwin\_MXDs\_Reports\Workplan G:\US_Army_COE_Sac\ERS G:\US_Army_COE_Sac\ERS\Ft_Irwin
Start Time: Tue May 15 17:00:57 2012
Running script MXDSourceUpdate...
  File "D:\TEMP\_Python\mxd_source_update_20120515.py", line 33, in <module>
    lyr.findAndReplaceWorkspacePath(origSource2, newSource2,"FALSE")
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\utils.py", line 181, in fn_
    return fn(*args, **kw)
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\_mapping.py", line 601, in findAndReplaceWorkspacePath
    return convertArcObjectToPythonObject(self._arc_object.findAndReplaceWorkspacePath(*gp_fixargs((find_workspace_path, replace_workspace_path, validate), True)))
ValueError: Layer: Unexpected error
Completed script MXDSourceUpdate...
Failed to execute (MXDSourceUpdate).
Failed at Tue May 15 17:01:00 2012 (Elapsed Time: 3.00 seconds)
I am not sure, but is seems like the arcpy module is trying to validate the paths.  My understanding was the script would work regardless of whether or not it found a valid path.  I tried explicitly setting the validation to "FALSE" which yielded the same result.  My MXDs typically have layers referencing many sources, I was hoping this tool would function as a true find and replace.  That is, it would ignore any layers in which it did not "find" the search string.
Any ideas?
Here is my code:
import arcpy, os
try:
    #Read input parameters from GP dialog
    folderPath = arcpy.GetParameterAsText(0)
    origSource = arcpy.GetParameterAsText(1)
    newSource = arcpy.GetParameterAsText(2)
    #Loop through each MXD file
    origSource2 = origSource.replace("\\","/")
    newSource2 = newSource.replace("\\","/")
                print fullpath + "\n\n...Checking"
                print fullpath + "\n\n...Updated"
                mxd.save()
    del mxd
    #Delete variables that reference data on disk
    del folderPath, origSource, newSource, filename, fullpath
except Exception, e:
        import traceback
        map(arcpy.AddError, traceback.format_exc().split("\n"))
        arcpy.AddError(str(e))
BTW it actually still crashes completely if I try to use mxd.findAndReplaceWorkspacePaths() after the layer test.  I would prefer this method as it is supposed to update all layers including table layers which are apparently missed by the layer.findAndReplaceWorkspacePath()... but maybe i am just missing something?
JeffBarrette
I'm not sure this logic will work.  For example, let us say I have a layer with the following data source:
C:\\temp\\lines
Your code [origSource2 = origSource.replace("\\","/")] is converting the string to:
C:/temp/lines
Then you are trying to perform a find and replace with a "find" string that does NOT exist in any of your sources because you changed it but perhaps that is why you are using validate=False.  I don't know enough to assess the error.
Can you send me just your MXD (no data) to jbarrette@esri.com.  From that I should be able to determine the data sources.
Jeff
StephenIrving
New Contributor II
"I may have found the issue.  It helps to try real scripts against real MXDs.
Change this line:
lyr.findAndReplaceWorkspacePath(r"G:\US_Army_COE_Sac\ERS\Ft_Irwin", r"G:\US_Army_COE_Sac","FALSE")
To:
lyr.findAndReplaceWorkspacePath(r"G:\US_Army_COE_Sac\ERS\Ft_Irwin", r"G:\US_Army_COE_Sac", False)
The validation parameter is a Python Boolean, not a string.  You want to use False with an upper case "F", lower case "alse")
Jeff"
The above worked perfectly! Thanks again!
