How can I export a 1 bit tif?
3483
11-15-2015 06:39 AM
ClintOffutt
How can I export a 1 bit tif file from ArcMap?  I am using the Image Analyst window to clip several 1 bit tif files (raster scans) and then using the mosaic to stitch them together.  I then want to export, or save to a permanent 1 bit tif, but the export automatically bumps it up to 8 bit.  I have also tried copy raster and forced to 1 bit output, but the quality is not the same.  I have done this operation exactly in the past and ended up with small, 1 bit mosaic tifs.  Maybe that was an older version on ArcMap.  I am running ArcMap Standard 10.2 and Advanced 10.3.  Thanks
DanPatterson_Retired
