Key Numbering Placement of Lists options
458
03-20-2014 10:42 AM
MichaelMartian
Dear ESRI - I would like to make a suggestion that it would be helpful to have more control over Key Numbering.  I have a map which required a lot of Key Numbering of streets for a local school board.  I had to convert them to annotation in the map and then copy and paste them into word, then create a box in the lower portion of the map to list all the numbered streets.  Would be marvelous if we could set up key numbering to do this instead of doing it manually.  [ATTACH=CONFIG]32365[/ATTACH]
Rae Kenny-Rife
GIS Tech
Yakima County
