Make a point representation
2640
09-08-2014 04:59 AM
MaartenBos
I want to make representation of points because a lot of points are close to each other on the map so you cant see them well when you are zoomed out.
The problem is that the point or label become invisible when you make a representation of it. When you are zoomed out you can see the point but labelling isnt working. When you are zoomed in to the point, you cant see the point. Do anyone know what the problem is?
HamidAli1
You can use label priority your lable problem will solve..........
Hamid Khattak
GIS Assistant
