I have a problem with annotations alignment. I already have created annotations from .dgn files and placed them correctly with FME (points represent anchors for every annotation).
After I change annotation class styles, the alignment "resets" even I have determined the 'Override' value for 'VerticalAlignment' and 'HorizontalAlignment'.
In figure, the name "Koskenkyla" should only change the font, not the alignment.
What could be the problem with 'Override'?
Solved the problem with symbol substitution and disabling "Symbol Substitution takes precedence over individual symbol overrides" -tag.
