Projection System from GCS_WGS_1984 WKID: 4326 Authority: EPS to Lambert Conformal Conic .
1149
09-24-2018 02:51 AM
JeevanBasnyat
Asia_Lambert_Conformal_Conic
Authority: Custom
Projection: Lambert_Conformal_Conic
False_Easting: 0.0
False_Northing: 0.0
Central_Meridian: 100.0
Standard_Parallel_1: 24.0
Standard_Parallel_2: 48.0
Latitude_Of_Origin: 36.0
Linear Unit: Meter (1.0)
when I tried to project data from GCS_WGS_1984 WKID: 4326 to Lambert Conformal conic projection with above-mentioned projection, why does the actual length of route different?
The distance calculated from skyvecor.com is different then obtained from the projected coordinate system?
