Rough Join
887
03-16-2017 02:16 PM
DougMerrick
New Contributor III
Is there any possible way to do a "rough" join between a featureclass and a table?
Similar to a lookup table in excel, I need to be able to have model builder approximate a unit rate if part of a feature code (ie. Water-Pressure Main-PVC-125 does not exist by Water-Pressure Main-PVC-150:$400 does) does not have a unit rate associated with the code. Ideally I would have unit rates for every code, but need a way to catch ones that I do not have.
Thanks!
