Metadata, Catalogs, and Search Blog
Latest Activity
(14 Posts)
Jill_Saligoe-Simmel
How do you create INSPIRE Metadata using the new ArcGIS metadata editor? This tutorial provides step-by-step guidance. The ArcGIS Online Spring 2024 release makes creating metadata in compliance with the European Commission Open Data Directive and INSPIRE Directive easier than ever.
Read more...
more
3 0 380
ShareUser
Esri Community Manager
This lesson steps you through using the ArcGIS Online Metadata Editor to create INSPIRE Metadata v2 for dataset metadata. With ArcGIS Enterprise 10.9+, this tutorial also applies to creating INSPIRE Metadata in the ArcGIS Enterprise portal. UPDATED 23-June-2021 to include steps using the new INSPIRE Reference Validator, plus additional tips to improve your data catalog.
Read more...
more
0 0 182
Jill_Saligoe-Simmel
With the Fall ArcGIS Online 2023 release, the new metadata editor is officially out of Beta.
Read more...
more
3 4 475
Jill_Saligoe-Simmel
New search capabilities empower users to easily and quickly find the information they’re seeking as well as discover new content. (cross-posted from the ArcGIS Blog).
Read more...
more
0 0 209
Jill_Saligoe-Simmel
Join us in San Diego for these metadata-related sessions and activities.
Read more...
more
2 0 539
Jill_Saligoe-Simmel
With the ArcGIS Online summer 2023 release, we introduce the metadata editor beta, a streamlined experience for creating high-quality geospatial metadata.
Read more...
more
1 0 326
Jill_Saligoe-Simmel
This lesson teaches you how to create ISO 19139/19115 Metadata for layers in ArcGIS Online using the metadata editor (classic) and following the FGDC Technical Guidance: Data.gov and The GeoPlatform Metadata Recommendations.
Updated (2023-04-02) - This lesson was updated to reflect the most recent version of the FGDC Guidance, plus minor grammatical changes.
Updated (2024-01-10 - This lesson was updated to reflect that it is for use with the Metadata Editor Classic.
Read more...
more
0 0 1,712
curtvprice
MVP Esteemed Contributor
Sorry to say, I kind of dropped the ball and didn't push Esri for a Metadata SIG in the virtual UC this year. I apologize, I simply didn't think of it.
Nevertheless, there is a lot of great content in the UC on open systems and interoperability, see:
https://community.esri.com/community/open-platform-standards-and-interoperability/blog/2020/07/13/jo...  and:Aleta Vienneau‌'s on-demand tech session: Understanding and Using Metadata in ArcGIS. Aleta recorded a nice video reviewing the metadata experience on Desktop and Online, and demonstrating value of metadata when rescuing old data. She also showed how to set up metadata on ArcGIS Enterprise so that metadata updates migrate and stay in synch to AGOL when edited. If you did not sign up for the EsriUC, the EsriUC content is expected to go public on September 1 (if not earlier).
Personally, I had some experience with the Python metadata module this year, using it in this tool DLG To GDB  that imports DLG data, I wanted to capture some of the information stored in the original DLG file in the metadata so it would not be lost to the sands of time. It worked great! So if you want to see a real-world example of that ArcGIS Pro arcpy module, you can download that tool. (Even if you don't have Interoperability Extension and can't run the tool, you can edit the script tool to look at the python code and see what it does.)
I did catch up with Aleta yesterday through the EsriUC networking tool. She is planning a Metadata SIG online meeting later this year, look for details posted here to the Metadata community soon.
Warm regards, metadata-heads! I missed meeting you in San Diego!
more
3 1 1,314
curtvprice
From the https://community.esri.com/community/events/user-conference/blog/2019/06/26/2019-uc-qa?sr=search&sea...‌ - reposting here for wider distribution
Standards-compliant metadata is already supported for items throughout the ArcGIS platform for viewing and editing in ArcMap, ArcGIS Pro, ArcGIS Online, and ArcGIS Enterprise. Support for more recent updates to the ISO 19115 standard (-1/2/3) are under development.
ArcGIS Online and ArcGIS Enterprise now allow users to view layer-level metadata for hosted feature layers from the layer's item page. The metadata is displayed in the style configured by the organization. Additionally, when exporting hosted feature layers to a file geodatabase or to shapefiles, layer-level metadata is included in the exported feature classes. At present, the layer-level metadata is read-only; it will be editable in the future.
In ArcGIS Pro 2.1, we introduced the ability for map layers either to reference a read-only version of their source data's metadata (the default), or to have their own metadata independent of the source data’s metadata. With the release of ArcGIS Pro 2.2, users are able to import metadata to an item, save a copy of ArcGIS metadata to a file on disk, and export an item’s metadata to a standard-format XML file. Users are also able to upgrade metadata created in ArcGIS Desktop 9.x (for example) to the ArcGIS metadata format so it can be viewed and managed in ArcGIS Pro. When publishing a map from ArcGIS Pro, the map’s full ArcGIS metadata will be published with the data and transferred to the portal item. Using ArcGIS Pro’s metadata import capabilities full metadata can be transferred from local maps to the portal items that were published with earlier versions of ArcGIS Pro.
When ArcGIS Pro 2.2 is used together with ArcGIS Enterprise the process of updating metadata for published content will be more streamlined than ever. If you publish a map service where layers reference data in an enterprise geodatabase that is registered as a data store item, and the map layers reference the data source’s metadata—updates to the feature class metadata are instantly available in the portal when someone views metadata for the service’s layers.
With the Pro 2.3 release (Jan ‘19), you can create Metadata for a Project and extend Pro with the Pro Metadata Toolkit (https://github.com/Esri/arcgis-pro-metadata-toolkit). The ArcGIS Pro Metadata Toolkit provides resources to create an Add-In that allows you to customize the pages that appear in the ArcGIS Pro metadata editor to suit your organizational, community, or regional requirements.
For the upcoming Pro 2.4 release, Esri will begin a phased approach for supporting the newer ISO 19115-1 and the 19115-3 specifications by first allowing import of an ISO 19115-3 metadata file; however, this file will lose any new attributes not supported by old standard upon import. Full support for ISO 19115-1/2/3 is planned for a Pro 2.5 release.
more
1 0 750
curtvprice
Date: 07/12/2017   05:30 PM - 07:00 PM
SDCC - Room 28 A
If you aren't attending EsriUC, you can also join online!   >> Register here <<
This Esri User Conference Metadata Special Interest Group has a long tradition going back at least a decade. The meeting will include informal presentations from Esri staff who work on implementing and supporting metadata across the ArcGIS platform. Esri participates in the ISO standards committees so we get an up to date status report on the ISO metadata standards process. This is a great opportunity to hear where things are going and to provide feedback to Esri.
Have you used the Metadata Toolkit? Have you developed an interesting or useful metadata workflow? We are interested in some informal user presentations as well. Contact me Curtis Price if interested in sharing your knowledge.
more
1 1 619
79 Subscribers
