Minimum Bounding Volume Tool Error in Model Builder ArcGIS Pro 2.5
562
11-07-2020 11:39 AM
by Anonymous User
Not applicable
I am attempting to create Minimum Bounding Volumes from clipped point features that have Z values, but the Minimum Bounding Volume Tool will not accept any 'modified' point feature as input in Model Builder (ArcGIS Pro 2.5) until I run the tool and generate the clipped points first. Of course this defeats the purpose of the model, as I wanted to publish this as a geoprocessing service in a Web App.
I get this error:  00241: The specified pathname or file type is invalid for the required input. My points are derived from a Multipoint feature.  I spoke with an ESRI expert about this at length and tried multiple avenues and they believe this is a bug, after observing my model's behavior.  Again, Minimum Bounding Volume will accept PilePts as input after they are created, but not otherwise.
I can input the unmodified point features no problem, without clipping, as shown below.  So I do not believe this is a data type issue.  But I don't see where I would put a precondition in either.  I am not using any additional parameters in the MBV Tool, so this should be simple.  My pathnames are fine (the Output Name variable is there, just not visible in the image). I have tried this in a folder and a file geodatabase.
Has anyone experienced this same issue with this or another tool?Minimum Bounding Volume Tool error.
DavidPike
MVP Frequent Contributor
Can you cheat it by using an Environment Variable (Processing Extent) on Points_with_Z, and have it as a parameter?
by Anonymous User
Not applicable
Of course THANK YOU!  I have been so focused on stringing other models together, I didn't even think of setting an extent.  Such an obvious workaround.  Now the trick is to see if this works with a Feature Set in a Geoprocessing Service...
