I am trying to automate a process to select polygons by location based on a different shapefile. This is the model I have built:
This model seems to be running in an infinite loop. What I am trying to do instead is to have it run through each of my 48,000+ data points from "DiatomsPoints" and select the polygon from "huc250kSUBSv2" for each point. Then, I would like the information to be collated into a table which shows the data from "DiatomsPoints" and the corresponding polygon from "huc250kSUBSv2". Is there a simple way to do this with model builder? I also have the Python code below, but I don't know how to code in Python (yet), so I'm not sure where I need to make changes, or even what changes to make. Thanks for your help!
Python:
# -*- coding: utf-8 -*-
# DiatomScript.py
# Created on: 2015-02-25 10:39:32.00000
# (generated by ArcGIS/ModelBuilder)
# Usage: DiatomScript <DiatomPoints>
# Description:
# Import arcpy module
import arcpy
# Load required toolboxes
arcpy.ImportToolbox("Model Functions")
# Script arguments
DiatomPoints = arcpy.GetParameterAsText(0)
if DiatomPoints == '#' or not DiatomPoints:
DiatomPoints = "DiatomPoints" # provide a default value if unspecified
# Local variables:
DiatomPoints__2_ = DiatomPoints
Value = DiatomPoints__2_
huc250kSUBSv2__2_ = DiatomPoints__2_
DiatomData = huc250kSUBSv2__2_
huc250kSUBSv2 = "huc250kSUBSv2"
DiatomDiversity = "C:\\Users\\an997533\\Documents\\DiatomDiversity"
# Process: Select Layer By Attribute
arcpy.SelectLayerByAttribute_management(DiatomPoints, "NEW_SELECTION", "")
# Process: For
arcpy.IterateCount_mb("1", "48606", "1")
# Process: Select Layer By Location
arcpy.SelectLayerByLocation_management(huc250kSUBSv2, "INTERSECT", DiatomPoints__2_, "", "NEW_SELECTION")
# Process: Create Table
arcpy.CreateTable_management(DiatomDiversity, "DiatomData", "", "")
