Problem with Calculate Value (ModelBuilder)
1107
04-16-2014 04:27 AM
HaniDraidi
Occasional Contributor II
I am using calculate value tool which is a �??model only tool�?�, the input is a string and the output is an Encrypted string. When the input is an integer like �??123�?� it works fine, but when the input contains letters like �??mmm�?� or �??a123a�?�, an error appears. How to make it work with letters? This is illustrated below by screenshots.
1-
[ATTACH=CONFIG]33140[/ATTACH]
2-
[ATTACH=CONFIG]33141[/ATTACH]
3-
[ATTACH=CONFIG]33142[/ATTACH]
4-
[ATTACH=CONFIG]33143[/ATTACH]
by Anonymous User
Not applicable
Original User: hua17
Hello Hani,
It's kind of stupid, but you have to include quotes if your specifying a string (even in the string tool). Try using "mmm" (with quotes).
[ATTACH=CONFIG]33144[/ATTACH]
Also, your question was great! Very well explained.
HaniDraidi
Thanks a lot, I tried it and it worked.
