Hello All,
I have developed two model builders - one for shapefile with 2 or more point features (that will be used to create multiple buffers and merge all buffer togethers), and one for shapefile with only one point feature. So far, I am trying to figure how to incorporate the "If then" to direct the tool to select correct model for processing.
The initial entry point would be "Shapefile.shp" into Get Count module which outputs the Row Count, then from there, am uncertain how to do this.
Any solutions?
Erick
You are right to consider the Get Count tool. The output of this itool will be the row count.
