My ESRI Tech Needs Expanded Support Categories
585
05-08-2023 05:56 AM
Status: Needs Clarification
SheriNorton
Occasional Contributor II
The My ESRI Support Categories and Subcategories are insufficient for both website and phone case submission. I have had many cases that do not fit at all in the limited categories/sub-categories. This is problematic, leading to delays in routing the problem to the correct analyst.
3 Comments
TeresaDolan
@SheriNorton
Thanks for your comment.
Could you supply some suggestions as to Categories and Subcategories that you were expecting to find, or that you would find useful? I can pass those on to the Support team for consideration.
SheriNorton
Sure - I had another case to submit today regarding annoying Locator errors for existing Pro Projects. In this instance, while the Customize, Configure and Develop Category is a reasonable choice, there are just two Sub-Categories (Add-Ins, Utility Network Industry Configurations). The Sub-Category is required, but neither of these limited options fits my problem at all. So I'm force to pick one of them regardless and hope the case gets routed to the correct analyst. Frustrating and inefficient.
TeresaDolan
@SheriNorton- Thanks for the details. I have passed your request on to the team that manages those lists.
