I want to implement a GIS based three Tier application. I prefer ASP.Net with C# (MVC).
Can anyone guide me how to start with?
I could not find any example where one can start ASP.Net (MVC). Or how to add ArcGIS maps into an ASP.Net web site.
I have downloaded .Net runtime but it does not show any ArcsGIS map when I select ASP.Net C# Web mvc. It has some ArcGIS for Andorid, Iphone and Xamarin etc but not for ASP.net Web Application. Please guide. I am using VS 2017. and Windows 10
I have managed to start implementation using Javascript API. Just to help others this is how I did.
As MVC supports javascript, html and c# code in one file so you can use javascript API and html samples of ESRI from below web site.
ArcGIS API for JavaScript | ArcGIS for Developers (Latest)
Steps:
1- Create a Controller and View.
2- Add following references in your _Layout.cshtml
<link rel="stylesheet" href="https://esri.github.io/calcite-maps/dist/css/calcite-maps-bootstrap.min-v0.8.css">
<!-- Calcite Maps -->
<link rel="stylesheet" href="https://esri.github.io/calcite-maps/dist/css/calcite-maps-arcgis-4.x.min-v0.8.css">
<!-- ArcGIS JS 4 -->
<link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
3- Use example like below and copy code in your view. You need to skip/comment out the code in step 2.
Calcite Maps and Bootstrap | ArcGIS API for JavaScript 4.10
4- Call view from your controller.
5- I personally separated the javascript, style sheet and html code in different files. Call them in view. Enjoy
Create your MVC application as normal and import the SDK that you will be using for instance the Javascript API and continue to build out your application from there using the documents online as reference.
Steps:
Exactly, you are well on your way to completing your project. I am using the same platform for a project I am working on with MVC.
do you get an error like this
