I followed the samples from ESRI (e.g. this one from GitHub) to enable feature-access to my service and everything worked fine. Next I changed the URL into my own feature-service and provided my crendetials to access that service.
So I ended up with the following code:
var serviceUrl = "https://myhost/arcgis/rest/services/MyService/FeatureServer/0";
ServerInfo serverInfo = new ServerInfo
ServerUri = new Uri(serviceUrl),
TokenAuthenticationType = TokenAuthenticationType.ArcGISToken,
TokenServiceUri = new Uri("https://myhost/arcgis/admin/generateToken")
AuthenticationManager.Current.RegisterServer(serverInfo);
AuthenticationManager.Current.ChallengeHandler = new ChallengeHandler(
async info =>
await AuthenticationManager.Current.GenerateCredentialAsync(info.ServiceUri, user, password,
info.GenerateTokenOptions));
var featureTableUri = new System.Uri(serviceUrl);
var table = new ServiceFeatureTable(featureTableUri);
var queryParameters = new QueryParameters { WhereClause = "1 = 1" };
FeatureQueryResult features = await table.QueryFeaturesAsync(queryParameters);
When I execute this code I get the following exception on the last line, which doesn´t seem very meaningful to me:
Exception thrown: 'System.InvalidOperationException' in mscorlib.dll
Additional information: Cannot call this method in this context: Object failed to load, unable to execute task.
When I set a breakpoint on the GenerateCredentialAsync-line (line 12) I also notice it´s never hit. So I wonder if the challengehandler is even registered correctly and fires the challenge-event appropriately.
