Changing MinScale and MaxScale on DynamicLayerInfo not working
4287
11-11-2015 09:14 AM
ColinWyatt
My code to update the DynamicLayerInfo scaling properties doesn't seem to work for me.
I can change MinScale and MaxScale on the DynamicLayer itself, but changing them for one of the sub-layers doesn't seem to have an effect.
If I try and remove and re-add the DynamicLayerInfo with the new values, the feature layer disappears.
I notice the Layer.MinScale/MaxScale uses double.NaN to indicate an unset value, whereas the DynamicLayerInfos have 0.0 as a default value.
Any ideas what I might be missing?
Thanks.
ColinWyatt
Looks to be the same problem as listed here:
GroupLayer.MinScale/MaxScale not working
