DefinitionExpression SQL questions
2528
05-28-2015 07:03 AM
BledarBirbo1
Hi.
I want to filter a featurelayer which is set to QueryMode.OnDemand. using the DefinitionExpression
After i set the expression to the layer i can track the requsets to arcgis server it the where clause only includes OID NOT IN (345,34,34)  it doesn't include my DefinitionExpression
It seems that ArcGIS runtime only filters the features in clientside.
What SQL Syntax is it using ?
How can i force it to send the expression to arcgis server ?
The published feature service it comming from an Oracle datasource and i want to use Oracle SQL syntax in the expression.
Thanks.
Tags (1)
