Detecting the presence of an attribute index on a runtime geodatabase class
382
02-21-2017 05:38 AM
EdwardBlair
Am working with a (SQLite) runtime Geodatabase with an app that relies on the presence of several attribute indexes to provide good performance.  Is there a way in the ArcGIS runtime .net SDK to detect the presence of an index so I can take some action if its not there?
Ed
EdwardBlair
Found my solution.  Just added System.Data.SQLite to my project and performed a query directly to the SQLite database to get the indexes present.
Ed
string dataSource = @"c:\MyDatabase.geodatabase";
SQLiteConnection sqlCon = new SQLiteConnection("Data Source=" + dataSource + ";Version=3;");
sqlCon.Open();
string sqlQuery = "Select sql FROM SQLite_master WHERE type = 'index' AND tbl_name = 'MYTABLE'";
SQLiteCommand sqlCmd = new SQLiteCommand(sqlQuery, sqlCon);
SQLiteDataReader sqlRead = sqlCmd.ExecuteReader();
string result = "";
while (sqlRead.Read())
result += sqlRead[0].ToString() + Environment.NewLine;
