In an earlier version of the .NET SDK we were able to remove the "for development use only" watermark with the following:
Esri.ArcGISRuntime.ArcGISRuntimeEnvironment.ClientId = "mYcLieNTid";
try {
Esri.ArcGISRuntime.ArcGISRuntimeEnvironment.Initialize();
} catch (Exception ex) { Console.WriteLine("Unable to initialize the ArcGIS Runtime with the client ID provided: " + ex.Message); }
With version 100.0.0 of the SDK it seems that the ClientId attribute is no longer a member of the ArcGISRuntimeEnvironment class. Has it moved? Is there a different way to add the client ID? Looking through the documentation I only see a way to initialize with a license or a named user.
Schuyler
This isn't needed any longer. Just set the license-key and you're good to go. See the licensing doc here:
License your app—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
