I have a mpk that has a Feature Layer where the features are labeled based on an attribute (which is just a string). When I am creating new features on this feature layer sometimes the label appears then quickly disappears. I believe it is due to a RefreshFeatures call off of the ServiceFeatureTable that is causing it to disappear. I know that the label should be there because when I pan the map, the label appears. I want the label to not disappear because it is confusing for any user. What steps would I have to take to Refresh/Re-render the layer when a new feature has been added (without having the user pan the map)?
Thank you
