the Runtime documentation describes five constructor, which could be used to create a FeatureTable. One of them creates a class based on a FeatureTable.
Normally, a FeatureTable is based on a service, such as the ServiceFeatureTable, and is usually stored in a database. But I need a FeatureLayer on the fly based on in memory data.
So I thought in my case the FeatureCollectionTable would be the right way, because it is based on a FeatureTable and so I should be able to create a FeatureLayer from it.
The following code is compileable:
var fields = new List<Field> {new Field(FieldType.Text, "Field1", "Field1", 50)};
var table = new FeatureCollectionTable(fields, GeometryType.Point, SpatialReferences.WebMercator);
var featureLayer = new FeatureLayer(table);
MyMapView.Map.OperationalLayers.Add(featureLayer);
But when executing this code, I got an exception:
System.ArgumentException: 'Invalid argument: Cannot create a feature layer from a feature collection table. Add the feature collection table to a feature collection.'
Now I'm a bit confused: Why can't I do that, a FeatureCollectionTable inherits from the FeatureTable?
Is that a bug? Is this work as designed?
A FeatureCollection doesn't get me where I want to be: Among other things, I want to be able to restrict data by DefinitionExpression, but this is only possible with the FeatureLayer.
Kind regards,
Max
