How to determine geographic coordinates of an object found using a local locator (.loc file)
764
06-06-2017 06:37 PM
YuriGvozdev
New Contributor II
I search for objects on the map using the local locator. The search works and finds objects. But I can not understand how to extract the geographical coordinates of the found volume from the search results.
NagmaYasmin
Occasional Contributor III
Hi Yuri,
You could set the OutputSpatialReference of the GeocodeParameters to "SpatialReferences.Wgs84" to get the geographical coordinates
GeocodeParameters gcParams = new GeocodeParameters();
gcParams.OutputSpatialReference = SpatialReferences.Wgs84;
IReadOnlyList<GeocodeResult> results = await localLocatorTask.GeocodeAsync("address", gcParams);
Debug.WriteLine("Latitude: " + results[0].InputLocation.Y + " Longitude: " + results[0].InputLocation.X);
Hope that helps. Thanks
Nagma
