We're having this issue again. Now the sync capabilities are enabled but the sync still fails. Is there any way to know what's wrong? The server returns a few status messages (InProgress), but then fails. The code works with an Oracle XE server, but I don't see any differences in the table structure or service definition.
Also: I haven't changed any data on the offline database. I just wanted to test if the sync works at all.
Service's sync capabilities are:
Supports Registering Existing Data: true Supports Sync Direction Control: true Supports PerLayer Sync: true Supports PerReplica Sync: false Supports RollbackOnFailure : false Supports Async: true |
I also checked the ArcGIS Server Manger logs and found this entry:
Failed in acquiring Archive Difference Cursor for Dataset: SCHEMA.TableName for Replica: SCHEMA.Ags_Fs_1421226240935 [GUID: A9BFF549-4F11-4707-A5C2-A6CE82826D2E]. Time taken: 0.032000 seconds. Underlying DBMS error [SCHEMA.TableName]
I've checked that we have the correct SDE version and archiving is enabled. Do you know anything else that we can do, antti kajanus?
