I am attempting to load a mobile map package from a UNC path (), but getting the following exception:
Esri.ArcGISRuntime.ArcGISRuntimeException: 'Internal error'
I am loading the map package with the following line:
MobileMapPackage sourceMapPackage = await MobileMapPackage.OpenAsync("\\computer_name\Share\OperationalLayers\OperationalLayers.mmpk");
I don't have any issues if I use a path to a folder in my local machine, or if I map the network location to a local drive. Are UNC paths supported, and if so, is this a bug or should I be loading it differently? This is with Runtime 100.1
