Is there a way to load raster images with world files in the .Net Runtime SDK 100.0.0? I have a .tif image and a .tfw file with transformation information. The following code block works with GeoTiff files, but not with generic .tif images:
var raster = new Raster(System.IO.Path.Combine(GetStorageDirectory(), "redickville.tif"));
await raster.LoadAsync();
var rasterLayer = new RasterLayer(raster);
await rasterLayer.LoadAsync();
Map.OperationalLayers.Add(rasterLayer);
There are no runtime errors, but the raster does not appear. Is there a way to include the .tfw file in this process? Or the projection information?
If I use a 3rd party tool to create a GeoTiff file using the same files, that raster image can be loaded and displayed correctly using the above code. I attached the files I used.
Thanks.
