Map labels overlap symbols in MMPK
481
03-29-2022 08:45 AM
o_pastukhov
New Contributor III
Our WPF application uses .NET ArcGIS Runtime 100.12 for displaying a map. The app targets .NET 4.7.2.
The app displays the map with some symbols created at runtime on it.
When the map is loaded as a map service, the symbols are on top of labels. However, when the map is loaded from mobile map package (mmpk), labels overlap symbols. See attached screenshots for both cases.
Labels from map serviceLabels from map service
Labels from mmpkLabels from mmpk
1) Can this be fixed somehow?
2) Does this bug report the same issue? If so, are there any time frames when this will be fixed? https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDE0Mzg2MA==
EricJing
New Contributor III
Hi @o_pastukhov
Have you fixed this issue for mmpk? I came across similiar issue. I don't know how to fix this. I asked some questions in community, but no one replied. If you have solution, can you please share? Thank you.
I am using ArcGISRuntime 100.15
MikeBingham
New Contributor II
We have not been able to fix this using ArcGISRuntime 100.15.3
