MapPoint.MoveTo in 3D
2478
05-06-2016 08:53 AM
TorreyStevens1
The MoveTo method only supports X and Y. If I try to use it on a ModelMarkerSymbol that has a Z value, it sets it to 0. This forces me to replace the Geometry of a 3D Graphic in a Scene which is not as efficient as MoveTo when trying to animate. What is the best way to animate a Graphic in a Scene?
Torrey
AnttiKajanus1
Occasional Contributor III
You should be able just to create new MapPoint for the graphic and assign that into the Graphic.
