Hi Preeti, sorry for the delayed reply. Please see the answers to your questions down below.
I tried reproducing this issue using a different feature layer from the same service and found that it worked as expected - in other words, all features are displayed. I'll need to check with our GIS administrators to see if they can spot any differences in how these layers and their data sources are configured.
- What do you see when you add that featureservice in ArcGIS Pro or ArcGIS Online?
When I add this service to ArcGIS Pro, it works correctly. All features are displayed on the map.
- Is 200.0 version of app, that display data correctly, using the same exact service that does not work with 200.2.
That's correct. The app that works is a WPF .NET app using the 200.0 version. The app that doesn't work is a .NET MAUI app using the 200.2 version. Note, I also tried upgrading to 200.3 and also downgrading to 200.1 and 200.0, but the problem persists in all versions I tried.
- What is the server version?
The server version is 11.1.
- What authoring tool was used to publish the service?
ArcGIS Pro
- How is Map's json constructed?
We created a simple .NET app to programmatically add the basemap and operational layers we needed, then called the ToJson() method on that Map object to extract the json. Note, however, that the problem persists whether we initialize the map manually or via the map's FromJson() method.
- Is it possible to share the service endpoint ?
Unfortunately, it's a sensitive layer that we cannot share externally. I'll see if we can generate some fake data and create a new service to replicate the issue.
David
