Runtime SDK 10.2.7 First QueryTask takes a long time
320
09-19-2023 09:17 AM
jgalarse
Hey guys,
I am having a weird scenario after upgrading to .NET 4.8. We are still using ArcGIS Runtime SDK 10.2.7. We are looping through our map layers and executing a query task, but the first querytask always takes 15 seconds and all of the next querytasks just runs under 1 or 2 seconds. We are using IdentityManager for the authentication.
Query Task Code:
QueryTask task = new QueryTask(new Uri(url));
query.OutFields.Add("*");
query.ReturnGeometry = true;
Task<QueryResult> queryTask = task.ExecuteAsync(query);
QueryResult result = await queryTask;
dotMorten_esri
Esri Notable Contributor
What version of .NET did you upgrade from where it didn't happen? Was this the only change you made?
(just on a side note, the v10.x releases retired four years ago, and we encourage you port to the 200.x releases if you can)
MichaelDavis3
What basemap are you using?
If it's imagery take a look at this old post:
https://community.esri.com/t5/arcgis-runtime-sdk-for-ios-questions/slow-laggy-performance-when-doing...
Query/Identify tasks will hit the image basemap and take a while to respond... We've had to specifically exclude that layer from query tasks to work around that issue for years now.
