Good afternoon!
We are loading polyline features into a ServiceFeatureTable using QueryFeaturesAsync, and noticed that although the QueryParameters class has a parameter for "ReturnGeometry", it does not have a parameter for "ReturnTrueCurves". I was wondering if ArcGIS Runtime SDK for .NET supports true curves in this scenario?
We are basically trying to roll our own real-time traffic solution since we are using our own custom road network. First, we want to load a set of traffic jam polylines from our feature service (some of these polylines will be true curves). Then, we create a new RouteTask against our Network Analyst service that uses our own road network, and we pass these polylines as CostAdjustment barriers to the SolveRouteAsync method.
This works great except for true curves... Our road network contains true curves in some places, and if we don't pass a true curve for these to the SolveRouteAsync, then it only minimally considers the impedance cost factor (just where the vertices of the polyline impedance come close to the vertices of the true curve road segment).
Perhaps there is a way to force Return True Curves = True when we publish our feature service - could that solve the problem?
Thank you!
