Why MapView is not displaying in some devices?
815
02-08-2019 11:41 PM
AbdulRAsheed
'esriUI:MapView' is not showing the map in some Android devices.(for example Android 7.0)
Instead of Map it is coming a blank space.
But Map is coming in another android device having save version.
RichZwaap
Could you provide some details on the specific devices you're seeing this behavior on and what your map contains?
dotMorten_esri
Esri Notable Contributor
...Also does all the layers switch to a succesful loaded state? If not, check their LoadError property to get an idea what's going on.
Also check the LayerViewStates on the layers (listen for MapView.LayerViewStateChanged) and check the layer states.
