How do I find the neighbours of each country and export that data to create a graph?
915
02-28-2020 09:29 AM
TiagoAlmeida
Hello, I'm new to ArcGIS and I would like to know how to create a graph of the world where each country is a node and exists a link between countries if they are neighbours.
Additionally, it would be perfect if each link had the distance between the centroids of those countries.
Thank you
DavidPike
MVP Frequent Contributor
Feature to point for each country to create centroud points. Make yourself aware of the output options in the help file. Also countries may have island territories and exclaves etc which will skew your points.
Use select by location to find neighbouring countries for each country and point to line for each country selected.
The actual process will be more involved than this simple explanation, and would best be scripted as it will need iteration.
TiagoAlmeida
Thank you, I was able to do it for one country but how do I make the script
now?
David Pike <geonet@esri.com> escreveu no dia sexta, 28/02/2020 à(s) 19:09:
GeoNet, The Esri Community | GIS and Geospatial Professional Community
<https://community.esri.com/?et=watches.email.thread>
Re: How do I find the neighbours of each country and export that data to
create a graph?
reply from David Pike
<https://community.esri.com/people/Davepike101@hotmail.com?et=watches.email.thread>
in New to GIS - View the full discussion
<https://community.esri.com/message/912307-re-how-do-i-find-the-neighbours-of-each-country-and-export-that-data-to-create-a-graph?commentID=912307&et=watches.email.thread#comment-912307>
DanPatterson_Retired
export the results of the run to a script
DavidPike
In the script turn the FC into a feature layer.
Use a select by attribute to select each country row within a for loop. Append the results to a point FC.
