Extract ArcInfo Grid in AGOL or Pro?
2390
08-03-2020 01:44 PM
BenHughey1
New Contributor II
Hi all,
I have a dataset that a colleague would like to use in analysis, but I can't seem to convert it to a usable format.
This hosted REST layer, TidalStream/usa_mc_tides (MapServer), appears to be an ArcInfo Grid (but I'm not positive about that).
Ideally, I'd like to extract or clip to the extent around Alaska and convert the file into a modern raster format, to be passed on for use in MatLab.
None of the geoprocessing tools in ArcGIS Pro 2.5 seem to accept the layer as a supported format.
Any tips for converting / working with this dataset?
Thanks!
Ben
Keith-VanGraafeiland
Hi Ben,
The Map Service you are referring to does not allow analysis, just visualization.  It's essentially a "picture" (tiles) of the analytical results.
I found the layer you mentioned on Marine Cadastre (search for "tide") and there was a link to a "data download" here is the source.... this should be the underlying data used to make the "picture"....
I hope this helps.
Marine Cadastre - Tide
Keith VanGraafeiland
DawnWright
cc Dan PattersonKevin ButlerKeith VanGraafeiland
Dawn Wright (she/her/hers), Ph.D. & GISP | Esri Chief Scientist
Hi Ben,
I hope this helps.
BenHughey1
New Contributor II
Thank you Keith VanGraafeiland‌! I was able to bring it into AGP and convert it after the download. Much appreciated!
