The mask in contour annotation tool isn't working
612
08-09-2017 03:48 AM
NathanMoore2
I've been trying to use the contour annotation tool to label bathymetry contours over a grid. The tool completes but the annotation mask doesn't seem to be working? Is this a known problem? I've been using the contour annotation tool in the past with no issue.
Any help with this would be appreciated.
XanderBakker
Esri Esteemed Contributor
Can you post a screenshot of the result you are getting, the tool(s) you used and settings applied? That would help to understand what is going on.
