This is my script ...but the properties do not get changed. Anyone know why?
# For Http calls
import httplib, urllib, json
# For system tools
import sys
# For reading passwords without echoing
import getpass
# Defines the entry point into the script
def main(argv=None):
# Print some info
print
print "This tool is a sample script"
print
# Ask for admin/publisher user name and password
username = "xxx"
password = "xxx"
# Ask for server name
serverName = "xxx"
serverPort = 6080
folder = 'Geobasisdaten'
# Get a token
token = getToken(username, password, serverName, serverPort)
if token == "":
print "Could not generate a token with the username and password provided."
return
folderURL = "/arcgis/admin/services/commandx/"
# This request only needs the token and the response formatting parameter
params = urllib.urlencode({'token': token, 'f': 'json'})
headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
# Connect to URL and post parameters
httpConn = httplib.HTTPConnection(serverName, serverPort)
httpConn.request("POST", folderURL, params, headers)
# Read response
response = httpConn.getresponse()
if (response.status != 200):
httpConn.close()
print "Could not read folder information."
return
else:
data = response.read()
# Check that data returned is not an error object
if not assertJsonSuccess(data):
print "Error when reading folder information. " + str(data)
else:
print "Processed folder information successfully. Now processing services..."
# Deserialize response into Python object
dataObj = json.loads(data)
httpConn.close()
# Loop through each service in the folder and stop or start it
for item in dataObj['services']:
# Edit desired properties of the service
dataObj["minInstancesPerNode"] = 0
dataObj["maxInstancesPerNode"] = 2
# Serialize back into JSON
updatedSvcJson = json.dumps(dataObj)
# Call the edit operation on the service. Pass in modified JSON.
editSvcURL = folderURL + str(item["serviceName"])+ ".MapServer" + "/edit"
print editSvcURL
params = urllib.urlencode({'token': token, 'f': 'json', 'service': updatedSvcJson})
httpConn.request("POST", editSvcURL, params, headers)
# Read service edit response
editResponse = httpConn.getresponse()
if (editResponse.status != 200):
httpConn.close()
print "Error while executing edit."
return
else:
editData = editResponse.read()
if not assertJsonSuccess(editData):
print "Error returned while editing service" + str(editData)
else:
print "Service edited successfully."
httpConn.close()
return
# A function to generate a token given username, password and the adminURL.
def getToken(username, password, serverName, serverPort):
# Token URL is typically http://server[:port]/arcgis/admin/generateToken
tokenURL = "/arcgis/admin/generateToken"
params = urllib.urlencode({'username': username, 'password': password, 'client': 'requestip', 'f': 'json'})
httpConn.request("POST", tokenURL, params, headers)
# Read response
httpConn.close()
print "Error while fetching tokens from admin URL. Please check the URL and try again."
return
else:
httpConn.close()
return
# Extract the token from it
token = json.loads(data)
return token['token']
# A function that checks that the input JSON object
# is not an error object.
def assertJsonSuccess(data):
obj = json.loads(data)
if 'status' in obj and obj['status'] == "error":
print "Error: JSON object returns an error. " + str(obj)
return False
else:
return True
# Script start
if __name__ == "__main__":
sys.exit(main(sys.argv[1:]))
