Is it possible to create and edit mosaic datasets via web tools / geoprocessing services?
I managed to publish and run a script tool performing an intersect with two shape files.
import arcpy a = arcpy.GetParameterAsText(0) b = arcpy.GetParameterAsText(1) arcpy.analysis.Intersect([a, b], f"{arcpy.env.scratchGDB}\\intersected", "ALL") arcpy.SetParameter(2, f"{arcpy.env.scratchGDB}\\intersected")
When I try it with the project home GDB path in the registered folder instead of the scratchGDB, I get an empty feature class and map layer. The two input parameters of the script tool are of type shapefile. I kept "add optional output feature service parameter" checked for the derived output parameter whilst publishing, so the output lands in a feature service and the map.
When I try to do something similar for creating a mosaic dataset, I get either broken project datasource or no error and no output. For example when writing the MD to the scratch GDB:
ERROR 000732: Mosaic Dataset: Dataset C:\Users\HACKEN~1\AppData\Local\Temp\37\ArcGISProTemp74484\scratch.gdb\S_col does not exist or is not supported
Failed to execute (MakeMosaicLayer).
I have tried it with the Model Builder, scripts and MDCS. I have tried using an existing Mosaic Layer. arcpy.management.MakeMosaicLayer() does not recognize the Mosaic dataset in the input. Do I have to work with image services on the image server for intermediate results?
import arcpy arcpy.CreateMosaicDataset_management(arcpy.env.scratchGDB, "mosaic_dataset","25832", "1","8_BIT_UNSIGNED", "NONE") #arcpy.management.MakeMosaicLayer(f"{arcpy.env.scratchGDB}\\S_col", "md_lyr") arcpy.management.AddRastersToMosaicDataset(f"{arcpy.env.scratchGDB}\\mosaic_dataset", "Raster Dataset", r"D:\FileShare_AGE\2022-11-24", "#", "#", "#", "2", "#", "#", "#", "*col.tif", "SUBFOLDERS", "EXCLUDE_DUPLICATES") arcpy.SetParameter(0, f"{arcpy.env.scratchGDB}\\S_col")
I have tried with datatypes mosaic layer, mosaic dataset, image service and feature class for the output parameter, as well as home gdb instead of scratch gdb.
