import arcpy
import pythonaddins
import functools
import os
import threading
import webbrowser
def run_in_other_thread(function):
@functools.wraps(function)
def fn_(*args, **kwargs):
thread = threading.Thread(target=function, args=args, kwargs=kwargs)
thread.start()
thread.join()
return fn_
openbrowser = run_in_other_thread(webbrowser.open)
class GoogleExtension(object):
"""Implementation for GoogleTool_addin.extension10 (Extension)"""
def activeViewChanged(self):
mxd = arcpy.mapping.MapDocument('current')
active_view = mxd.activeView
# tool1 is the tool ID (without the namespace prefix)
if active_view == 'PAGE_LAYOUT':
tool.enabled = False
else:
tool.enabled = True
arcpy.RefreshActiveView()
return
class MapChannels(object):
"""Implementation for GoogleTool_gmcaddin.tool (Tool)"""
def __init__(self):
self.enabled = True
self.shape = "NONE"
def onMouseUpMap(self, x, y, button, shift):
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
dfsr = df.spatialReference
if len(dfsr.type) > 0:
pass
else:
msgbox = pythonaddins.MessageBox('No Coordinate System','Oops!',0)
print msgbox
sys.exit("Unknown projection")
in_memory = "in_memory"
fcname = "pnt_name4444aj"
#x,y = [2424419.971, 864749.537]
fc = arcpy.CreateFeatureclass_management(in_memory,fcname,"POINT","","DISABLED","DISABLED",dfsr)
rows = arcpy.da.InsertCursor(fc,["SHAPE@XY"])
xy = (x,y)
rows.insertRow([xy])
del rows
sr = 'GEOGCS["GCS_North_American_1927",DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]'
for row in arcpy.da.SearchCursor(fc, ["SHAPE@XY"],"",sr):
adx,ady = row[0]
#print("{0}, {1}".format(adx, ady))
for lyr in arcpy.mapping.ListLayers(mxd, "", df):
if lyr.name == fcname:
arcpy.mapping.RemoveLayer(df, lyr)
url = "http://data.mapchannels.com/mm/dual2/map.htm?x=" + str(adx) + "&y="+ str(ady) + "&z=16&xb=" + str(adx) + "&yb="+ str(ady) + "&bar=1&mw=1&gm=0&ve=2&sv=1"#&svb="+ String(computeAngle2(startPt,lastPnt))
openbrowser(url)
del mxd,df,dfsr,in_memory,fc,xy,sr,row,url
