Densification.... sometimes being dense is a good thing
528
01-18-2018 11:22 AM
DanPatterson_Retired
1 0 528
Yup... adding points to poly* features
Already offered... Densify at all license levels?  NO!
My missive .... Densification by Factor  YES!
There is also a Geodesic Densify, but I don't do Geographic in any event, so use esri tools
Why did I reinvent the wheel?  Because the densification basis is to simply provide a sequence of locations, for X and Y then subdivide the intervening location by some factor (hence the ... by Factor)
Here is an example....
a = np.array([[ 20.,  20.],
              [ 20.,  30.],
              [ 30.,  30.],
              [ 30.,  20.],
              [ 20.,  20.]])‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Then you run some code
def _densify_2D(a, fact=2):
    """Densify a 2D array using np.interp.
    # Y = a changed all the y's to a
    a = np.squeeze(a)
    n_fact = len(a) * fact
    b = np.arange(0, n_fact, fact)
    b_new = np.arange(n_fact - 1)
    c0 = np.interp(b_new, b, a[:, 0])
    c1 = np.interp(b_new, b, a[:, 1])
    n = c0.shape[0]
    c = np.zeros((n, 2))
    c[:, 0] = c0
    c[:, 1] = c1
    return c‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
And you get this.
a_dens = _densify_2D(a, fact=2)
a_dens
array([[ 20.,  20.],
       [ 20.,  25.],
       [ 20.,  30.],
       [ 25.,  30.],
       [ 30.,  30.],
       [ 30.,  25.],
       [ 30.,  20.],
       [ 25.,  20.],
       [ 20.,  20.]])‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
a.shape  # (49874, 2)
%timeit _densify_2D(a, fact=2)
5.25 ms ± 323 µs per loop
     (mean ± std. dev. of 7 runs,
      100 loops each)
Where it really shines, is for long features that just need to be densified without any particular requirement for a set spacing.  If is fairly speedy as well.
Hope someone finds this useful, if you don't have the Standard or Advanced license in particular.
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
