Acces Metadata for map service Arcpy
3487
04-18-2015 03:37 AM
EQUIPEIS
HI communauty geonet, and users,
I try to update the metadatas (summary, details, Authors, ...) of many mxds in a folder and when i execute my python script all is ok (no error).
When i have for exemple 3 mxds in a folder, and when i open the propriety of the first mxd in the list the information is ok.
But when i  open the second mxd the information in the case is null. And when Open Mapdocument the information is ok for this second mxd.
My problem is for my second script when a push the mxds in arcgis server. On the service map the information is ok for the first and not for the other. My code is this one (sorry for my english):
# -*- coding: cp1252 -*-
#import modules
import arcpy, sys, os, string
import xml.dom.minidom as DOM
import codecs
#Read parameters from dialog
filedoss = arcpy.GetParameterAsText(0)
u = arcpy.GetParameterAsText(1)
Summary = u.encode('cp1252', 'strict')
i = arcpy.GetParameterAsText(2)
Description = i.encode('cp1252', 'strict')
o = arcpy.GetParameterAsText(3)
Author = o.encode('cp1252', 'strict')
Credits = o.encode('cp1252', 'strict')
fileanc =  arcpy.GetParameterAsText(4)
MapPath= []
MapFolder = os.listdir(filedoss)
arcpy.env.workspace = filedoss
for file in MapFolder:
  fileExt = os.path.splitext(file)[1]
  if fileExt == ".mxd":
  MapPath = os.path.join(filedoss, file)
  arcpy.AddMessage (MapPath)
  #set map document to change
  mxd = arcpy.mapping.MapDocument(MapPath)
  base = os.path.basename(filedoss).upper()
  #Nouveau nom
  file_name_temp = "NOM_" + base + "_" + file
  #arcpy.AddMessage ("MXD a sauvegarder :" + file_name)
  arcpy.AddMessage ("MXD sauvegarde :"  + file_name_temp)
  # Test existence de la sauvegarde
  if os.path.exists(file_name_temp):
  arcpy.AddMessage("Fichier mxd existe")
  try :
  # essaye de le supprimer
  os.remove(file_name_temp)
  except :
  arcpy.AddError ("Fichier non sauvegarde : impossible de le supprimer")
  sys.exit()
  #change Title
  mxd.title = file_name_temp
  #change Summary
  mxd.summary = Summary
  #change Description
  mxd.description = Description
  #change Author
  mxd.author = Author
  #change credits
  mxd.credits = Credits
  #Update map document tags
  #Generate unique, sorted list of layer names
  layers = arcpy.mapping.ListLayers(mxd)
  layerList = []
  for lyr in layers:
  if not lyr.isGroupLayer:
  layerList.append(lyr.name)
  uniqueList = list(set(layerList))
  uniqueList.sort()
  tagList = ",".join(uniqueList)
  mxd.tags = tagList
  for lyr in layers:
  if lyr.supports("DATASOURCE"):
  lyr.replaceDataSource(filedoss, 'SHAPEFILE_WORKSPACE', lyr.datasetName, False)
  #set relative paths property
  mxd.relativePaths = True
  #update Thumbnail
  mxd.deleteThumbnail()
  mxd.makeThumbnail()
  #save map document change
  #SAuvegarde sous nouveau
  mxd.saveACopy(file_name_temp)
  arcpy.AddMessage ("Fichier sauvegarde")
  arcpy.RefreshTOC()
  arcpy.RefreshActiveView()
  arcpy.RefreshCatalog(file_name_temp)
del mxd
EQUIPEIS
i publish an auto-reponse for one problem. But it's not resolved totaly.
The old MXD came from an Arcgis 9.3 and the properties is not update if i d'ont open Mapdocument
in the version 10.2.2. The link to the default database is null. When i open in Arcmap the link is ok tio the default geodatabase.
But i have a lot of MXS and it's impossible to open all. My question is :It's possible in ArcPy to automatilly
like the others properties (Summary, Authors ,...) to put this information of default geodatabase for many old MXD ?
Thank a lot
