One approach to determining the appropriate properties for cases like this is to change the data you'd like to change from Python, save the result as a new project, then extract the two APRX files and compare the related JSON CIM representations, and compare them with a diff tool. The documentation as recommended by @alfredman is the better approach, but sometimes seeing what the code actually changed can also be useful.
