I created an add in with 2 combo boxes and I would like to add a reset button to my toolbar. So the toolbar will be the same as when I open Arc Map.
I found this code on stackexchange and i'm trying to adapt it but i'm still got errors.
class ButtonReset(object): """Implementation for TestAddin_addin.reset (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): #Déclaration du mxd self.mxd = arcpy.mapping.MapDocument('current') layer = arcpy.mapping.ListLayers(self.mxd, "",df)[0] #Reinitialiser tous les couches de leur sélection arcpy.SelectLayerByAttribute_management(layer,"CLEAR_SELECTION") self.resetTool(combobox1, "") combobox1.enabled = False self.resetTool(combobox2, "") combobox2.enabled = False arcpy.RefreshActiveView() def refresh(self): pass
Also I put the function below as proposed under the module declaration but not sure if it's the right place to put it.
import arcpy from arcpy import env import pythonaddins def resetTool(toolID, defaultValue): toolID.value = defaultValue
Here the error I get when trying to run my reset button :
\TestAddin_addin.py", line 438, in onClick self.resetTool(combobox1, "") AttributeError: 'ButtonReset' object has no attribute 'resetTool'
Thanks for your help
