Add layer from current folder
644
6
11-20-2017 07:02 PM
Mohd_NurhafiziSaidin
Hye everyone,
I have create one Python file, the task is to add layer from the latest or current folder following date of folder. The sample folder is below;
Sample of folder
This is my sample code on Python;
import arcpy
import os
# suppose you want to add it to the current MXD (open MXD)
mxd = arcpy.mapping.MapDocument(r"C:\Users\User\Documents\MTSB_JPS\MXD\test.mxd")
dataFrame = arcpy.mapping.ListDataFrames(mxd, "*")[0]
# base folder
workspace = r"C:\Users\User\Documents\MTSB_JPS\Flood_Forecasting_Outputs\TRN"
walk = arcpy.da.Walk(workspace, topdown=False, datatype="FeatureClass")
for dirpath, dirnames, filenames in walk:
    for filename in filenames:
        layerfile = os.path.join(dirpath, filename)
        addlayer = arcpy.mapping.Layer(layerfile)
        arcpy.mapping.AddLayer(dataFrame, addlayer, "BOTTOM")
        mxd.save()
arcpy.RefreshTOC()
arcpy.RefreshActiveView()
del addlayer, mxd
The problem is, this code can't add the layer from the latest or current folder. It should add the layer from "20171117_0600_AF" but when I run this code, it add the layer from "20170701_2000_AF" folder.
Please help.
DanPatterson_Retired
is topdown=False correct?
have you put in some print statements to see what is being returned at each step in the loops?
Hye Dan,
Yups..topdown is correct. The result of print statements is below;
print output of loop
How I want add the shapefile from the last folder, thats mean the bottom of printout. Because in this root folder, the folder with date will be update with the new folder following by date. My task is to pick up the latest folder (CURRENT date) that contain the shapefile.
Thank you.
I guess I am not seeing the desired outcome list versus the list in the way they are being added.  If it is a matter of the order in which they are added, it could a sorting issue
Thanks Dan
Yups..it's a sorting issue. On progress to solve the debugs.
RebeccaStrauch__GISP
On a quick look, to me it looks like the for loops are going to try to add all layers.  Maybe you can grab date part of the name and do a compare until you find the latest?  Or it if it will always be the last item on the list, get a count and try to grab that.  Just a few things to try.
Thanks Rebecca.
For now, I try to using combination of loop and sorting. Let's see how it goes and if it doesn't, we'll try something else.
