addin tool not selecting by location
1584
12
04-13-2018 08:09 AM
KevinBell1
I'm making a python addin select tool that allows the user to draw a rectangle and then select points within it to then do stuff.  For testing I'm only counting how many points are selected and writing to a log file, but it always returns 0... What am I doing wrong here?
def onRectangle(self, rectangle_geometry):
   ext = rectangle_geometry
   array = arcpy.Array()
   array.add(arcpy.Point(ext.XMin, ext.YMin))
   array.add(arcpy.Point(ext.XMin, ext.YMax))
   array.add(arcpy.Point(ext.XMax, ext.YMax))
   array.add(arcpy.Point(ext.XMax, ext.YMin))
   polygon = arcpy.Polygon(array)
   arcpy.CopyFeatures_management(polygon, "in_memory//Polygon_Extent")
   arcpy.MakeFeatureLayer_management("in_memory//Polygon_Extent", 'selectLyr')
   arcpy.MakeFeatureLayer_management('events', 'eventsLyr')
   arcpy.SelectLayerByLocation_management('eventsLyr', 'INTERSECT','selectLyr')
   n = arcpy.GetCount_management('eventsLyr')
   f = open(r'E:\ArcMap\BuildingServices\20180411_misassignedInspectors\addin\log.txt','a')
   f.write(str(n) + '\n')
   f.close()
   arcpy.Delete_management("in_memory//Polygon_Extent")
   arcpy.Delete_management('selectLyr')
   arcpy.Delete_management('eventsLyr')
RandyBurton
MVP Alum
As a test, do you get a count if you check just before the SelectByLocation?
# check here to see if layer has a count
print n
KevinBell1
Yes!  I do get a count if I forego the selection.  If I do the select by location the count is zero, with out it 258 which is correct.
KevinBell1
ESRI Tech support got me going!
   arcpy.SelectLayerByLocation_management('eventsLyr', 'INTERSECT',rectangle_geometry.polygon)
   f.close()
